Just wondering how many Bike Dealers are willing to DO the install. If you had a dealer install your tires Please GIVE a Big Shout OUT. :thumbup:
My front KENDA tires are 20,000 miles and still going strong without ANY issues.
My rear KENDA tire was replaced at 13,000 miles but could have EASILY gotten 15,000 out of it.
If it "aint" broke don't fix it.:banghead:
Go ahead and put a harder rubber compound tire on your ride.
Go ahead and complete your genius by making sure it support 4x the bikes weight.
Go ahead and emergency brake as you slide into that jackknifing trailer.
Go ahead and later comment........Road-Kill was right.
Why would BRP want to do that?
When I was in Quebec last year for the Spyder 10th anniversary celebration I asked a BRP rep if they had any objection to dealers installing car tires. He said there was no such directive........
If you have to do that much work ...... just take the wheel / tire to any car tire place and have it done for $10 to $15 .......Mike :thumbup:When I had ours changed by a dealer, he said "as long as we don't remove or install the wheel(s) from the machine, we can mount the tires". So removed the rear wheel from the machine and took it to the dealer, had the tire (Yokohoma S-drive) mounted/bal. and was on my way back home. Still cost me $45.00 for the "service" though. Mad Mac:yikes:
You missed a few dealers in British Columbia ... LOLI have discussed the dealer in previous tire threads. My dealer is one that will NOT install non OEM tires on the :f_spider:. They are now the ONLY dealer in the state. Next nearest dealer is 1500 miles South (Washington State) or East (Whitehorse YT.).
My dealer would not mount them either even tho I called first and they said they would if I brought everything in. Had them mounted at a local tire shop and brought them back to the dealer and they even refused to balance them.
This is why I think BRP should clarify its policy, since some dealers have mounted non-OEM tires and others won't. If it's a complete ban due to liability issues, that's one thing. They should also clearly state whether they'll accept a rider signing a waiver absolving the dealer of any issues arising from use of non-OEM tires. And if so, riders must supply the tires; the dealers shouldn't have to source them.
I would just like some consistency.
1- We don't sell a tire
2- We get the dirty end of the stick (mounting and maybe balancing someone else's tire). Which takes shop time and really, not much profit in it.
3- We have the potential of inheriting someone else's problem. What happens if the tire is defective. What happens if the customer is not happy with the tire. What happens if there are clearance issues, etc.
4- Though I think most dealerships use this as a ruse to get you to purchase a Kenda. I think some dealerships actually believe there is a real potential for liability. While I will admit, anything is possible. I have never heard of a single related issue using a non-Kenda tire on the Spyder.
5- It may be that BRP has not issued any kind of blanket policy prohibiting dealerships from mounting an aftermarket tire. But they may have issued a policy stating that if a dealership does mount an aftermarket tire. The dealerships assumes all liability and BRP will not stand behind them if there is a problem.
Bottom line. It's just not worth the effort for most dealerships. But they aren't going to tell you that. They are going to give you a 'Story'. Blaming it on a BRP policy (whether it it exists or not) is a handy and efficient way to do that.
