OEM Horn function when bike is off?
Thank you for all the input! Glad to know its not a 'flaw' I found.
I am in the process of putting in the Stebel and thought I'd also use that + lead to feed my voltmeter thinking it was on switched power; that is how I discovered it was not cause the meter never turned off.
Ok, good to know then. I can easily tap into a different switched power lead, so no big deal.
Thanks again!
The horn switch is in the ground lead side of the horn. The power side is always hot.
