I'm curious - has anyone or any organization even done any OBJECTIVE tire testing on the Spyder re: tire pressures and handling, braking, acceleration, etc.? We read a lot of "butt" dyno reports (and I'm not discounting any of that as the butt can be very accurate), but (see what I did there?) actual testing with numbers and data sets?
Track tests, cone tests, braking distances at different pressures under the same controlled conditions?
And the differences in same on a unladen F3 vs a fully loaded RT - I would like to know with data sets what affect a pound (two pounds, three pounds) +/- actually has.
Or I will have to get off my lazy butt and spend an afternoon in an empty parking lot with the air compressor, stopwatch and measuring tape for myself.
Apart from you doing that sort of 'home grown' testing yourself with your uncalibrated and self-admitted 'lazy butt' & no control over a large proportion of the range of conditions etc that may effect results in a parking lot somewhere, it's really
very expensive to do that sort of testing in any helpful/reliable way Dan, and the people who pay for that sorta testing are generally pretty strict about where any of
their test results &/or data gets used &/or published, so it's not likely that you'll get to see much of the sort of detailed data that I reckon you're looking for
here....
You could search the magazines, or possibly find a utube channel or two that's done some limited testing vaguely along those lines on some of the tires that you might be interested in trying, but it too will probably reveal little in the way of the data you want and besides, I doubt there's too much out there involving Spyders & suitable tires in the applicable sizes... as others have said, the market is just too small to justify the expense! :banghead:
However, I have managed to get my 'educated & frequently calibrated butt & driving/riding skills' involved in
some testing of that sort on a variety of tires/vehicles over the years (spent a whole coupla days of it just recently on the new release Michelin Pilot Sport - fantastic tire!
hyea: Just no sizes that'll fit straight onto a Spyder; and a
very strict agreement on leaking details....
) & during the last 10 years or so have even managed to squeeze in some runs on a few different Spyders & a limited range of readily available tire brands & sizes - but since someone else was always paying for it, those 'strict rules' commented upon above apply, altho I've shared what I can (well, occasionally a bit more, but that truly wasn't intentional & won't be repeated!
pps: ) & hopefully expressed it in 'laymans terms' that
most might've found to be maybe juuust a
little helpful... :dontknow:
I'm sure that Mike's also been constrained in what he can & can't share about his experiences with investigating tires & how they've actually performed under the stressful conditions he was called in for, and I believe he too has shared what he can in a way that most people might find helpful, so I believe the best you're ever likely to get on a Forum like this will be the largely anecdotal info you've already seen, with little in the way of data - unless of course, someone wants to spring for the rather large 6 or more figured sum required for a day of the measurable & repeatable testing under (vaguely) controlled conditions that tire manufacturers so often use their secret squirrel computer modelling tools to conduct these days, just cos it's so expensive/difficult to do in real life!!
. I might even even look at volunteering to drag my 'educated & frequently calibrated butt & driving/riding skills' outta retirement to be involved if someone did..... altho last time I looked, there weren't too many suitable facilities for that sort of testing with much in the way of 'free time' for the forseeable future - they tend to be either owned or booked fairly solidly for years ahead by organisations that have faaaarrr deeper pockets than you'n me, and aren't above using the depth of those pockets to their fullest advantage!! :banghead:
So the parking lot is starting to look pretty good, hey?!
