OBD 11
Can one use an onboard diagnostic scanner on 2014 RT, and where is the OBD port on the Spyder........
As prev stated you need the BUDS to actually connect to the byke. But you can retrieve active (current) codes by doing the method in this video from Lamont @ Lamonster garage. Some codes will go to being "stored" codes (which then would require BUDS to retrieve) as soon as you shut off the key so leave it running if you have the warning light on.... Some codes are retrievable after the key is off I believe but to make sure you are getting all of the currently active ones related the light if it is on, better to leave the key on....
