Mowin, that rear 'tractor' is there to help provide power (for any hills especially, but also for getting & keeping things moving on the flat) and also to provide steering for the tail end of the load platform which is hanging between the pulled/towed pushed/driven multi-articulated trailers at each end. So there's load carrying ability and articulation in a whole heap of places through-out the entire rig, just not immediately under the load platform!! :shocked:
That whole rig is very similar to those pioneered here on the Snowy Mountains Hydro-Electric Scheme, altho our steep & narrow mountain roads & the need to move 200 ton rotors etc often called for the running of
TWO multi-wheel-drive tractor units connected to those 3xtriple bogie articulated 'load platform' trailers at each end, with the actual load then slung between the trailers! And SMHEA didn't have
ANY 'slave facilities' or electronic rev or speed matching devices to synchronise the driving when they did it, so each tractor driver had to manually drive their particular power unit to within a bees' mickey whisker's tolerance of all the others!! :yikes:
But it's bloody amazing the sheer
size of some of the gear they actually move around these days, isn't it!!
