Ok, I'll say it. I'm confused. The title implies you're not too satisfied with the LED's, but the pictures seem to show more illumination for both high and low beams as compared to the stock lamps. Please expound a little more, I'd appreciate it. Alway looking for improvements.
In the original post, if you expand the pictures they are clearly named as to which is which. To me the LED's look good, but I don't know. Maybe I'm missing something. 50 watts is about 4 amps assuming 12 VDC, less if you sue actual 13.5-14.5 VDC.
Amps don't "compensate" for volts. Higher volts also means higher amps.
Higher voltage results in a higher wattage, given a constant ohmic resistance. You can also figure wattage as amps squared x resistance.
It would have been nice if the LED would have lit up the tree trunk, then there would have been a clear winner. Still, the whiter light usually gives better visibility, and it appears to draw quite a bit less power off of the charging system, leaving more power for other things.
4 sided LEDs I find give a better light disbursement then two sided LEDs when put in lights not made for LEDs. Halogens have 360 degree light and most two sided LEDs don't give that 360 degree range. I have similar LEDs on my wife's F3L and it puts out really good light. I tried the two sided ones and they were horrible.
