noisy trans - clatters
Proper oil level is critical. Check to see that you are in the operating range. Detailed instructions for how to properly check are in the owners manual.
Vehicle must be warmed up. Most recommend driving it about a half hour--then checking the oil level per specs.
Another...!!
seems to be alot of this going about. Not knowing anything about your spyder other than its an SE5 will have to agree with akspyderman. Start with the oil condition and level. This could be a clutch problem mor than a transmission. Don't know how it shifts or if it shifts nor if it does it hot or all the time. Could be the output shaft bearing :dontknow: if not mechanical good idea to have someone who is (or dealer) have a listen. :thumbup:
