No power to right fender
Curious...🤔
There are no individual fuses to each fender....but if you are replacing the wires I would start by checking all the connections and seeing if you have power at the source of your new connection. Did you check power with a meter or just the light connection..? if you are using LED bulb remember they are sensitive to the correct +/- connections...:dontknow:
