spyder stryder
Ok,back to the springs. If & when you order a set of shocks & springs for your bike tell the supplier
that you want a matched rated springs & settle for no less. What i mean by this is say you have a
set of factory springs on the bike & the guy tells you that you need a pair of 275# springs or what ever.
He should have a spring rater & check the springs so he can match them up on the rate. The spring
can be stamped 275 & rate at 260 with the other rated at 285 if so you just shot your whole deal.
I have seen quite a bit of off rated springs from every spring supplier out there. Just make sure you
get what you need on rates & shock valving. On these anti roll bars bigger the bar the stiffer it is
with the same length & arm length. With limited space where the bar mounts if you can't mount a
bigger bar then take a look at mounting it from the back side. You would have to fab up some chassis
brackets so you can bolt it on then use the stock mounts for the ends to mount back. Don't panic
it works the same no problem there if you have room at the back side. Guess i could take a look myself.
Also if you find a longer bar with the rateing you need you can mount it as long as the tire dosn't hit
it as the wheel is turned. The closer to the wheel the ends mount the better control it will have on roll.
