NO CLUTCH
2Gunns
RT-S PE#0032
Go ready to head out this morning, but I have zero clutch. loose as a goose. Is it a fuse?
Any help that will point in the right direction would be greatly appreciated. (2010 RT-S)
Do you have fluid in the reservoir? :dontknow:
I seem to recall some issues with the fluids eating an o-ring in the system; causing everything to need some pretty quick cleaning and adjustments...
Take a look for posts like this from Nancy's Toy...
Se5 or Sm5..??
not a fuse usually oil related but your not having any clutch seems strange. What exactly is happening. It may be the shift lever is off if it seems to shift but not go anywhere. Do you have any fault codes..?? Was it fine the last ryde and when was that..?? :dontknow:
clutch
I to have a 2010 RT-S which lost my clutch. The bike has been in the shop for two weeks now and no fix. New clutch kit, new master cylinder still no go :opps: Dealer says BRP not coming up with any answers. Now mechanic is on vacation
it was fine last ryde.... the clutch is just not there (no resistance). I managed to get into neutral, but if shift gears and it bogs down
SAME PROBLEM
I JUST HAD THE SAME PROBLEM I WAS TOLD I HAD TO REPLACE THE CLUTCH ITS IN THE SHOP NOW IT SHOULD BE OUT SOON FOLLOW UP WHEN ITS FINSIH
BUT MY PROBLEM WAS MY BIKE WAS BOGGED DOWN ALSO I COULDNT GO OVER 25 AND COULDNT MAKE IT UP A HILL OF ANY INCLINE
That was it, resevior was completely empty
Top it up bleed it out should be good. Look to see what's leaking annual clutch hydraulic fluid changes will extend life of master/slave
Sent from my HTCONE using Tapatalk
Little checking..!!
if the resevoir was that low you need to find out why..why you got no warning..and fix the leak...:lecturef_smilie: You don't want this happening on the road...:thumbup:
