NMN tail light install
barb36jack31
Lamonster - You had a posting with pictures re subject install. I now have the iail light kit, but cannot find your original posting. Please advise!
Thanks,
Jack H.
I'll look for the post but it's real easy. Just drill a hole and mount the light.
Use the taps to connect the wires as color coded.
Unplug one of the tail lights, doesn't matter which one, then plug the new light in.
Successful Install of NMN Tailigtht
It seems that the Triple Play system I had already installed some time ago was not fully compatible with the new Tail Light kit. I could not see how the various wires should go. A quick call to NMN solved the problem. A few wires had to be released from their epoxy case, followed by extending their length and finally hooking it all up as per instructions from NMN and VOILA! everything worked. NMN offered to update my Triple Play system, but they also told me how to make my system work with the Tail Light kit. Many thanks to NMN for all their help . I now have a safer Spyder and will enjoy the additional lighting for a long time. Thanks again!
