Night Dash
Depends...
Not sure if it is in the same location on all guages but if you take a black felt dot and float around the cluster you will find the spot...:thumbup:
There is a sensor on the cluster, find it and cover it with some black tape. I'm sure someone on here knows the exact location.
I have tried that and it didn't work. The sensor was too sensitive and it still reverted to the daytime setup. By the time I had enough tape to do the job half the instrument panel was covered :dontknow:
