QuadManiac
Air/fuel ratio also significantly affects pre-detonation, so if you're 'juiced' a little lean, you are likely to have pre-det with the appropriate knock sensor reduction in timing advance and concomitant performance. Higher octane in this case should help overcome the pre-det and return the lost performance.
