BLACK WIDOW
91 octane
Good informantion--This pretty much parallels my thinking.
Pretty accurate analogy.
Our Spyders run a compression ratio that is too high for regular. This isn't theory, this is fact.
Sure BRP says you can run regular and the Spyder does fine on regular. No one is disputing this. But how is it that both are true?
There can be only 1 answer. BRP has modified other factors which reduce performance and allow for octane lower than our compression ratio requires.
Can we get some performance back by raising Octane? This is where the debate is because only BRP knows how this game is being played.
I found this on a High Performance Engine web page.
KNOCK-SENSOR-EQUIPPED VEHICLES
Automakers began using knock sensors in the late 1970's. When knock occurs it sends a signal to the main computer, which retards the spark timing until detonation ceases. The best thing about a knock-sensor is its ability to reduce or eliminate engine damage due to detonation. It can, however, cause spark-timing retard, which reduces horsepower and fuel economy. Using a gasoline high enough in octane to satisfy the engine under all types of conditions will ensure maximum performance.
Here is a Minimum Octane vs. Compression Ratio chart. With a compression ratio of 10.8:1 and no modifications for knock our Spyder would require 100 Octane, minimum.
So, all things being equal, even premium fuel won't get us where our compression ratio requires us to be. Even with premium we still need an anti-knock system because 92/93 is not enough.
The question is, will higher octane get our ECM to give us a more advanced spark timing, thus improved efficiency, power and mileage?
BRP could tell us for sure, but we can also experiment. That is what I have done.
