Next Gen Spyder Drvetrain
If you could choose the next generation drivetrain for the Spyder which would it be
  • Total voters
    205
AVBIZ
Next Gen Spyder Drivetrain
If you had a say in the next evolution of the Spyder drivetrain which would you pick?
Drive
:coffee: A shorter drive belt and or maybe a drive shaft. :popcorn: This would be above my pay grade. .....:thumbup:
Probably should have included “Electric” options - apologies since I cant seem to edit the poll now.
Administrators- any way to pin the poll up top for a few days? When submitters update the poll it doesn’t send it back up to the top.
Thanks
I choose the increased displacement, since one can never have too much power, but even downsizing to the 900cc in a F3 and instead add a turbo would be a pretty interesting option IMO. :)
I rode the snowmobile with the 900Ace Turbo last weekend. Wow....excellent power rush right from the crack of the throttle.
I voted shaft drive, more engine displacement, automatic transmission.
I see you got the information for posting a poll. RE: question about pinning it to the top. I am not sure that is possible. It will go to the top every time someone posts. You can do a self help by posting the word "bump" or similar at the bottom. That will bring it back to the top again.
Thanks for the tutelage! I gave up on it last night but tried again this morning after a cup of strong coffee and was successful. :) Hopefully we’ll see a healthy response rate.
Good subject, inquiring minds want to know, etc. I think your good here. :bowdown:
I think any drive train change that would up the mileage to 35 or 38 mpg (US gallons) would get my vote. The rear tire life is long enough, I feel a belt is ok even though a shaft is superior (which probably would hurt mileage though). And a 6-cyl Honda engine probably would get worse mileage than the current triple.
I have a Honda F6B with the 6cyl. and I believe it would do much better mpg. Also, it hasn’t been back to the dealerships not once! That’s a big plus with me. :thumbup: cueman
Its easy to vote for what we think is the best option but the real question is what are you willing to PAY for a change to what you have now?
I would pay a handsome sum for increased performance. Not so much for shaft drive.
The belt has given very little problems over the years and shaft drive opens a whole new can for very little benefit.
Now a 4 cyl 1600cc engine or a 1300 turbo.....200hp sounds about right ;-)
Hah! You would think its easy - anonymous submittal by clicking a button; yet only approx 17% response rate :) Still interesting though 89% favor a shaft. I like the shafts ease of maintenance and the ability to travel over non paved roads without worry.
Kind of like the old Cummins in a Ford truck body thing, my take is a Honda 1800 flat engine with the DTC transmission wedged in this thing with a shaft drive would make an absolutely wonderful ride. No rocks to worry about with the belt either!
I voted same displacement with shaft drive.
Would like to have easier to fill tank to the top feature, better fuel efficiency, no wait time from key on to start button active, more aerodynamic windscreen (would help fuel efficiency), higher quality tires from the factory, good stabilizer bar from the factory, power plug on dash instead of in trunk-DUH
edit: same displacement in a turbo diesel.
<gulp!> <inhales morning coffee!>
A Spyder with a DIESEL?
Makes some sence for a commuter or long distance, where fuel economy is relevant, but personally I would never want any kind of bike (2 or 3 wheel) with a Diesel engine.
yep. we're on our second diesel VW car now and know without doubt a properly built and finely tuned small diesel engine has surprisingly good acceleration. Of course the torque per displacement is unmatched by anything in a gas engine of he same size. Possibly the biggest negative to overcome would be the heat; but with some logical thought, I'm thinking that could be easily managed as well. Then you would have a Spyder capable of 60 to 80mpg.
First 24 hour summary:
* Most Popular setup: Shaft/Increased Engine Displacement/Semi Auto Trans
* 92% of respondents would like to have shaft drive
* Riders still like to “go through the gears” with 64% opting for a Semi Auto Trans; although a full Auto Trans has a strong following
* 71% of respondents would like more HP
* Surprisingly only 8% want to continue with a belt final drive
Interesting informal stats. I’ll summarize again in a week. BRP are you listening? :)
