Well i'm new here. Riding a goldwing 1800 now but have some health issues, wife says we should look into the Spyder roadster.So here i am trying to find out all i can. Been riding 53 yrs. only had one three wheeler
back in 70's vw trike.Didn't like it all that much.
I really like mine with the exception that the seating of my RS is horrible for me. I am 54 and have just had some pretty major surgery so I bought the Spyder. I would definitely consider the RT if you are going to do it. I am looking at the Seal footboards to see if I will be able to do anything about the riding position..
The RT is Way less than the RT even if you add the hard saddlebags, a world class windshield, lower wind screens, rear rack with a color matching rear top case, handlebar risers, and Hopefully the seal floorboards. to get you sitting right. I will keep you posted on the saga of getting this thing to sit well...
That being said I have had Harleys most of my life and recently an old Goldwing. I have to say that the Spyder is real kick to ride...drive... whatever. It is amazingly quick once you learn to get the RPMs up above 5 grand... 6 really.
This thing handles really well around curves, once you learn how to ride/drive it..
Here are the issues I suspect you will have
It takes a while to learn to ride if you are used to a motorcycle. I found myself constantly trying to lean it and often scared myself because it just wouldn't do what I wanted it to... Steer it Cole....... not lean
Forget about dodging pot holes on crappy roads... if you put it between the front wheels the rear one is sure to get it.
When you are riding down the road and there are little bumps on one of the front wheels and not the other it feels like you are starting to shimmy.... (Goldwing flashback)
When you are around town or on country roads it seems to take more exertion to ride because of having to or at least thinking you have to shift your weight back and forth. I am guessing as I learn how to ride it better I will quit wrestling with it and things will go better.
If you are used to a Goldwing this may not be an issue to you, but if you want to do ANYTHING on this thing mechanically except remove the front wheels you are going to be tearing body panels off to get to what you are working on. I do admit though the panels come off pretty easily.. they are held on with plastic snap down rivets, and torx head screws. I think an electric screwdriver (not a drill) would be very useful here or an air ratchet.
That is a complete list of my observations so far.
OH...
When you change oil you drain both the engine AND the oil tank...
Oh
Horrible gas mileage for a small vehicle with a fairing. I really don't understand why.. I figured the way the front end was built it would do much better. I have a theory that the front fenders are the cause. That and the high rpm idle and power curve of the engine.. AND the low final drive ratio.
this thing runs 2500 rpm at 35 in 5th (high) gear. A quick calculation tells me that the top speed without overreving is around 130... I have seen mixed stories about how fast it will go. ... Myself.. It still scares me that I will forget how to operate it again if I ride it very fast so I havent:2thumbs: been over 70 yet. I never ride very fast anyway... I am more of an acceleration guy myself.
I am still at the learn how to steer it every time I get back on point and I have owned it for over a week. I am guessing that this is typical of people who have ridden on 2 wheels their whole long lives....
overall.... I love this thing.
