Newbie Question re Vibration
ncmedic
I'm still new to the Spyder, having had my RTL for 3 months and a little over 1,500 miles.
I notice something that may or may not be a problem. On the interstate, if I start up a hill, there is a vibration that I think comes from the drivetrain. As soon as I crest the hill, the vibration disappears.
Does anyone know what causes this??
:agree: But tell us more about the vibration...
At what speeds does it occur?
What gear are you in?
The drivebelts will often set up a harmonic vibration at speeds in the 75 mph range (give or take a bit...)
But if you're cruising at a relatively low speed in top gear (say about 38 to 40 mph): the drivetrain will vibrate a bit if it's under a load...
feel it through the foot rest
I usually feel the vibration through the foot rest at crusin speed of 55 or so ! when the throttle isn`t giving much push , just easing down the highway , you can roll on the gas a bit and it goes away , this is the belt drive , lopking at doc`s damping system at some point in time !
