Newbie ! I need a little help please !
its a 6.6 gal tank with the air space being that .6. When gauges say empty you have little more than a gal left. I always figure whaterver I am getting to the gal is how far I can go. Best is when the setting is at empty look for a gas station. Congrats on the new ryde and joining in here...welcome..!! :thumbup:
Thanks ! Back at you ! :2thumbs:
All advice good. The gas gauges (analog or digital) are there to give you a "ballpark" of what is left in the tank. Once you have filled up--I recommend setting a tripmeter to zero. Fill up to the same level each time. Don't overfill. You will note that your refill gas light will come on at mileage X for your particular machine. Usually just a little over a gallon left. Most people fill between 135 and 150 miles. If you get the "usual" 30 mpg, then your looking at 5 gal or less. The important thing is to get to know your particular machine and fill up before you run out. I have stretched it out to 184 miles and 5.8 gallons on my 2010 RTS. The new 2014 RT's are better with average 40 mpg and a 200 mile range between fill ups.
Thank you ! :2thumbs:
