Newbee questions-2012 RTS
d.o.spyder-rts
Is anyone experiencing a fuel odor after riding? I noticed it before my first refueling (it took 5 gal) and even after the tank was full. Possible causes? :dontknow: Is there a low fuel warning light for the RTS? Dale
evaporation canisters are the most likely culprit. As Scott had posted earlier when refueling insert the pump nozzle just past the flapper and fill gently, stop after it trips first time. Others with more knowledge of this problem will add to this
later. Ride safe:yes::ohyea::clap:
Yes, there is a fuel warning light on the RTS. If you did not have a light, and put in 5 gallons, you likely overflowed to the evap canister. You will not get rid of the gas smell for a log while to come. It evaporates very slowly from the canister.
When filling, fill as slowly as possibly...at least after the first couple of gallons. Insert the tip of the nozzle just into the opening in the "No-lead" ring and stop when gas just begins to spit out the vent slashes. The fuel level should end up approximately 1/2" below the low part of the neck. That is full, when you account for the necessary head space.
