How would I know if I needed the SmoothSpyder belt tensioner device??
When I rode my new RT Limited home, to keep from getting run over on I-70, I had to go 80 MPH by GPS. At that speed I noticed a rhythmic "feeling" in the seat of my pants on the straight segments. I did not notice it when I was going thru the long sweeping curves. The next morning I checked my tire pressures. All tires were:
1. at the minimum recommended tire pressures, and
2. there was 5 pounds difference in the front tires
I inflated all the tires to the maximum recommended pressures(22 in the fronts and 30 in the rear). Any suggestions for an easier way to access and fill the rear tire?????????
The weather has turned rainny and cold here, so I have not had a chance to get my LTD out and see if the ride has smoothed out.
Thanks for any advice for a new RT owner.
