viperryder
Merry Christmas to all Spyder ryders. There is a new item for your Christmas list. It is inserts for your 12 spoke wheels. They are very easy to put on and look GREAT. First you will need to clean the spokes with a cleaner, I used acetone, as it leaves no residue. Wiped with a clean rag and applied decal. I stared with the small end of the decal in the top end of the wheel. Then placed the round end on the center of the wheel and stuck it the center. Slowly apply pressure starting at the center moving to the top of top of the slot. Any air bubbles can be worked out with a solid item, that will not cut the material. It does not matter what rib you start with, just work your way around the wheel until all 6 decals are applied. Good luck and they look GREAT. Merry Christmas.
hyea:
