New to Three Wheelers. Long time on two
Wetduc
Riding 2 wheels since 1967.
Recent health reasons have compelled me to buy a Ryker.
It's definitely different, with very little of my experience applicable. The "twitch" keeps me very alert 🤣🤣.
I just received a steering stabilizer. I'm hoping that helps.
Ride Safe
I'm in the same boat so Welcome Aboard :2thumbs: Just fitted a stabiliser but haven't been able to test it yet. Will be interesting to hear your findings.
A “steering stabiliser”? Do you mean a sway bar? That will certainly change handling characteristics, but the major reason for the “twitch” is YOU, Wetduc ;)
You are gripping the bars too tight, which leads to over correcting, resulting in the twitch you are experiencing. It happens to all new Ryker/Spyder riders in one form or another. Loosen your grip and let the Ryker have its head a little, and read the riding tips link that Copper has posted above. The twitch will soon disappear.:2thumbs:
Pete
No, I mean a steering stabilizer, not an upgraded sway bar. As far as gripping the bars too tight, that is not the issue. I realize that the twitch is not there on Spyders due to the electronic power steering. On my rally it improved once I softened the suspension a little for my 150 lb frame. On smooth roads it's quite manageable but we are eating up with road snakes. Ride Safe down under ��
Welcome! I see you are in NC - Check out the 'Triangle Spyders' group if you are on facebook. We are doing a ride next weekend (9/7) to the NC mountains. Going to travel up to the Boone area; hop on the BRP; and take that down to Little Switzerland. Then we're heading home (Apex/Cary area). You're welcome to join us for any part of the ride.
Been riding 2 wheels since 1979. I got the Ryker this spring. I had a little trouble getting used to it. I started with bar end links and dialing in the tire pressure. In my case the dealer had all the tires over inflated. That did it for me. No more twitch. I looked at the stabilizer and had that on the list as a next step but I cured my issue a little easier. Hope you get it figured out. Welcome to three wheels!
The more you ride it the more comfortable you will get.
Like you I started riding in the sixties. I was on here for about a year before I got the Ryker and had some idea what to expect.
Three wheels takes some getting used to (the first day I kept putting a foot down at a stop. LOL)
The damper helps. What setting do you have it at? I have mine set on #4 right now.
Lots of good advice here.
The damper helps. What setting do you have it at. I have mine set on #4 right now.
Gotcha!
Got the stabilizer installed this afternoon. However, the Liquid Sunshine prevented me from testing it out. I did the initial setting at 4. Thanks.
