Good day, I just purchased my first 3-wheeler, having discovered that I can no longer trust my wonky knee to hold up my motorcycle. I have some concerns about the handling of my new Spyder - specifically, at speeds over 50 mph, I find the steering wobbles. It doesn't dive to the side, it just sort of wanders a bit. So, my question is: is this normal for a 3-wheeler?
NO ! EMPHATICALLY. IT IS NOT NORMAL.
A properly tuned Spyder rides like it's on RAILS at speeds up to 108 MPH. DAMHIKT.
Something is WRONG.
There are many possibilities.
1) Riding Technique. Some say your grip is too tight, and you may be overcompensating the steering.
2) Air Pressure in the tires. The front tires should be pumped up to about 20 PSI and the pressure should vary less than 1/2 PSI between the left and right. When the pressure is too high, the Spyder "Sits up on the balls of it's feet" and is very sensitive to small variations in the road.
I can't see the year of your Spyder. Perhaps something is age related? Is your Spyder used or new?
3) Tire Problems. The tires may be damaged, perhaps a cord in the tire has slipped. It may be the tires are not balanced properly
4) Steering Linkage. Maybe something in the steering linkage is worn, such as a ball joint or tie rod end.
5) Alignment. The earlier models (pre 2014) had front end alignment problems from the factory. Maybe a previous owner hit a curb or something else? The solution is to get a laser alignment.
I'd recommend looking into the easy fixes first. Check your tire pressures and the condition of the tires. Are they out of balance? Perhaps a balancing weight fell off.
If that doesn't fix things for you, see about getting a laser alignment. As I said before, a properly aligned Spyder will track like it's on rails.
Maybe when you take it for an alignment, you can have the suspension checked for physical damage/worn parts.
Rest assured, there is a solution, you just need to find it.
Good Luck, keep us posted so we know how you make out.
