Jetfixer
Well-known member
Talk about learning a lesson the hard way. I finally decided to get the Federals and Altimax mounted and put on the fully sintered brakes that have been laying around for a couple of months. I watched Finless' videos a hundred times and then realized that there are numerous differences between his bike and my 15 RTL. All went well until I decided to check my belt tension after reinstalling the rear wheel. (I did not move the adjusters. Per the videos, I was able to just slip the belt off and back on). It was astronomically higher than it should be. So I did what seemed like the right thing to do and started messing with the adjusters. I got it dead on perfect using the called for Gates Sonic Belt Tester. Then I decided to check the tracking. I started the bike, put it in gear and let it spin a little. The tracking was slightly off, so I tweaked the adjusters again, got the tension perfect again, and started it up again. Well the belt tracking was perfect right up until the "Brake Failure" and "Limp Home Mode" indications came on. Great. It was right about this time that I found myself on the floor again staring straight up at that very nice belt tensioner that I installed quite some time ago and forgot about completely. This time, I held the tensioner up off the belt and would you believe that my belt tension was now astronomically low! I swear if I had had a stupid hammer within reach I would have hit myself with it for being so stupid. So needless to say, I repeated the entire process until it was correct.:banghead::banghead::banghead::banghead:
