New Spyder owner-backrest/luggage rack question
Jbuffalo
2009 Spyder, gs, with a Smoothspyder backrest. Will the stock back rack plate fit on this bike? I have a back cover that is attached with one screw and comes right off. Looking for some place to put luggage. thanks Jim
It will still work with the backrest you have now. However it will require a frame insert that the back rack should come with (I haven't checked as I have a 2015 which takes the newer stuffs and a different frame insert) that the sport rack base bolts to.
It isn't a difficult install, even with the frame insert... I've heard the hardest part is running the release cable/pull knob under the seat. Here's a video from youtube on how to install it. While this video finishes up with him adding the backrest, you'd simply snap on the luggage rack instead, so the install would be the same:
https://www.youtube.com/watch?v=sqmMhaUtg9E
Cy
