New Shocks / Suspension Fault
Exactly adjust the spring some but then you may have to adjust the dampening a bit or it could get harsh over bumps. It took me some trial and error to find my sweet spot.
We just went through this with my wifes 2018 F3 Limited. Ours was after putting on Elka shocks. We went to one dealer 3 times and BRP had them check and reset the switches and then they ended up replacing the compressor and it still did not fix the problem. We worked with ELKA and set the shocks to the min and max specs.....still with no fix. We finally went to a different dealer who again worked with BRP.....then they asked the question to BRP that we had been bringing up....."RIDE HEIGHT"
There is a way that the dealer can set the ride height with the computer system and some weight (I believe the procedure by BRP to set ride height is using 200 pds and the computer system). Problem fixed!!!!!!!!!!
Hope that helps
John
