BajaRon
Well-known member
Thanks! :thumbup:
I've only touched down once on our roads... :shocked:. It was enough to let me know that ground clearance is in short supply.
Does this adjuster start out at the stock setting, and just ramp up the preload from there? If that's the case; I guess I'd start out a maybe two turns in, and see what happens.
(Kind of looking for a starting point...)
The Shock Adjusters start out at the stock spring pre-load. So you can always return to the OEM setting if you wish. I do suggest 2 full turns as a ball-park place to start. Everyone is going to have different needs and preferences on how they want their spring pre-load set. That's exactly why I made these.
Frankly, even I am a bit surprised at the amount of difference these adjusters make to the ride in several different aspects.
Experimentation is the best way to find your sweet spot. My feeling is that most will find that (X) number of turns is best when unloaded with 1 rider. And (x+) number of turns is best for 2 up and loaded.
If you are bottoming out now, you're probably going to want just a bit more ground clearance. With 2 turns you not only get a bit more ground clearance, but your Spyder will not dive as deeply into the potholes as before. So your functional 'Ground Clearance' is actually greater than just the amount of physical lift you get with the adjusters. This will also give you more stability and take the 'Mush' out of the suspension.
Too harsh? Just back off a turn or 2. Too soft? Just give the adjusters a turn or two in the other direction.
Sounds a bit like the Goldilocks Story....
