New Se-5 will not start at the hotel...help
One other thought... Is this an SE5 or SM5 (Manual). If an SM5 it may be the clutch sensor up on the handlebar not fully engaging (Seen this happen once or twice)
When you turn the key on do the dash lights come on? If so then check the kill switch to make sure it is switched to run not stop. Also make sure you are stepping firmly on the brake otherwise no juice to starter.
If the dash lights do not come on you may have a loose battery connection. If that is the case you may have problems getting to the battery posts easily. You do have to remove the left side panels to check and tighten the connections. Good luck
When the message scrolls on the dash, you have to push either the button marked M on the dash or the button marked "mode" just ahead of the left hand grip ( other side from driver's view). Be sure your foot is on the brake.
