Same Problem with Our 2012 RT-S
We own a 2012 RT-S, and we've started having the same problem with strong gasoline odors, and liquid gasoline dripping from the evap cannister overflow line, after a long ride, and a nearly empty gas tank. After reading many posts on this forum, we know better than to even come close to overfilling our gas tank. We took our Spyder to the dealership a few weeks ago, and all they did was replace the evap cannister. As soon as we rode our Spyder home from the dealership, the evap cannister overflow line was dripping gasoline again, so obviously, the cannister wasn't the only problem. My guess, after reading the technical manual, and lots of posts on this forum, is the purge valve has failed. We're taking our Spyder back to the dealership again, and I'm going to insist they troubleshoot the blasted purge valve, this time around, not just throw another cannister at the problem. If the purge valve isn't broken, then my guess is the vapor recovery system design itself is flawed, somehow. If so, BRP needs to fix the problem, ASAP, with a voluntary recall. California is pretty harsh, when it comes to vehicle emission violations, so BRP would be much better off handling the problem themselves, before Sacramento finds out about it! nojoke
Sincerely,
Paul and Linda
