new pc
lonnibdd
O boys and girls i am so excited sold my jb thanks member should be there tomorrow. and just ordered my NEW POWER COMMANDER. :ohyea:
Will be here Friday already preloaded with my map for my bike anyone have a better map for 08gs w/ Two Bros silp on and stock air box w/knfilter? If so hit me up please would be interested in talking with you If anyone has any tips for installing these do's dont's lay it on me. I think they hook same as jb? cant wait:yes:
If I remember correctly, power and rpm sensor wires that need to be tapped and a ground and two cables that plugs into throttle body should be it.
Plug in o2 modifier.
Get the pc software, calibrate throttle position, and may be accel-pump if hesitation occurs off the line.
Add little fuel if popping occurs at decel at certain rpm range.
Subtract fuel just above 6000 rpm at low throttle to save fuel if you cruise at that range which should be just above 80 mph. :thumbup:
For those who have jb pro, do you calibrate throttle position?
if you dont mind me asking how do you calibrate throttle position just going through the steps in manual or is it through the software? This is alittle new territory for me. Dont get me wrong i wrech pretty well just not sure on these issue you brought before me thanks Bill Taylor.
does it come with o2 mod or you have to buy that seperate i had bought one and sold it i was under the impression you didnt need that anymore?
It comes with dynojet's o2 modifier.
It is a huge part of pc for spyder and one they had most problem with and delayed pcV for spyder a long time.
Download the pc software and instruction. I did it on LCD but I am thinking it would be on one of the tab on pc software.
It's pretty simple. Hit "calibrate" button and a quick throttle all the way and you are done!
