Greetings All,
I am a new Owner of a 2019 F3 Limited. I have to admit that after my first few rides I was afraid that it may not have been the wisest purchase of my life. I have now found that the more I ride it, the more it makes me giggle. After 3500 miles of us getting to know each other I have several questions and/or concerns. Unfortunately I am finding that I have more knowledge of the workings of this machine than my local Dealers (sadly this is not hubris). Worse yet, BRP is of absolutely no help (but I expected this from past BRP product contact attempts). I would greatly appreciate feedback on the following;
1. Do they all sound like sewing machines at cold idle?
2. My drive belt rides against the inner sprocket stops. The Owners manual states that it should not. The Dealer states that they all do and it is of no concern. What say you?
3. I have a drive belt vibration under load at hwy speeds. Apparently, from my research, so do you (unless you have installed a tensioner). So my question is this, is the BRP tensioner adequate or should I go with an aftermarket? To date I have purchased all BRP accessories, arm rests, fog light kit, cover, etc ('cause I'm like a trained monkey). If the BRP tensioner is adequate and/or recommended, has anyone had success in having it installed under warranty?
4. The audio/nav system was very quirky. I learned there was an update that was not performed on my bike prior to delivery so I just had that taken care of. I'm hoping this will have fixed long delays of no audio output at times. My real question here is, is it worth my time to master the BRP connect system or should I just use my phone nav and stream audio direct?
5. I would like to increase the exhaust decibels so that I no longer "sneak up" on my Harley friends. I don't want obnoxious but additional performance would be welcomed. I really don't want to spend $1,000.00 for the Akra...whatever exhaust that BRP and others offer. Any consensus on exhaust out there?
6. Has anyone out there wired 12V aux or USB, using a trim plate, to the steering wheel movable or stationary cowls on the F3 LTD?
...and now the $300.00 question...
7. I wish to increase the stability in the twisties. I am pretty sold on the Baja Ron bar and links however I have read that the F3 Limited has upgraded shocks and some feel this bar does not improve stability as much as a result. Are there any F3 LTD Baja Ron fans out there. *since my original post of this question I have pulled the trigger and ordered this kit.
I look forward to your feedback.
EKIRT on!
*Disclaimer - All of the opinions expressed in my posts are my own and are generally unpopular with others, but they are mine, so I like them.
EKIRT on!
