Have anyone tried the new juicebox pro?
I was wondering if it performs better than the regular juicebox.
Cost: $339.98
It looks like the PC5 will have an auto tune option, that the JB Pro doesn't appear to have. The Power Commander also has capabilities for peripherals that JB Pro doesn't. The autotune feature would probably sway me, due to the difficulty in finding a dyno that will accommodate the Spyder in order to obtain a precise tune.
The 'canned maps' you'll get from either manufacturer will be close(and better than anything we have now), but won't be as exact as a full tune on a dyno. The autotune will go a long way toward dialing in an individual machine without any dynomometer access......
I have an SE5, so the only way it could ever be dyno tested would be to take it back home to Valcourt and ask them to do it for me. For some reason I do not see that happening. I do know Two Bros. has been dyno testing this system on a Spyder, so the canned SM5 maps will be a good start for me. I can then tweak if need be; however, chances are without a dyno I would never be able to tell the difference anyway.
I believe it was stated before that none of these units will adjust the ignition timing, doesn't that make it the major limiting factor for performance tuning a Spyder?
Also, if I am reading things right, the AutoTune for non-Harley is a $260 add on.
Se5 can not be dynoed?
I wondered why they did not ask me if I had a se5...
Well if that's the case, I am gonna ask for auto-tune instead of Ron wood slip on they are offering me along with pc.
It is my understanding, a big thanks to Magic Man goes here, that in order to dyno the Spyder they have to disconnect the VSS. This works fine for the SM5; however, the SE5 will not shift out of first gear with the VSS disabled. BRP is supposed to have some software that will let them override this limitation, but they do not let it go to outside parties. This includes dealers, as they do not want anyone taking a Spyder on the road with the VSS overridden.
I wonder if DynoJet will have a way to temporarily overcome that little nuisance......
Thanks for the additional information.
So do you think the juice box pro is a little too technical for the average rider? Is seems like there needs to be a lot of education needed for the pro... or like a dyno is needed to fine tune the bike... so basically the difference between the pro and regular jb is being able to customize the maps better?...
Thanks
I don't really think it is going to be too complicated. I am fairly certain it will come with pre-set maps that will work for the most common set ups. Such as 1 for stock, 1 for exhaust only, 1 for exhaust with filter change, and so on. These should be really close to what is needed. You could also store maps for high altitude, cold weather, hot weather, and so on.
The biggest difference is that where the Juice Box could only add extra fuel to the system, the Pro can also take away fuel. This should help give better air fuel mixture in all areas.
Its my understanding the :spyder2: runs lean now . Would you want to take fuel away ?:dontknow:
