SteveLaoyster
I finished installing my new horns & relay last week. I'll try to get a sound bite on before the end of the week.
Just as a heads up while doing the wiring for the horn I discovered that the battery did not sit properly to put on the battery hold down. I found the the cable to the starter was pulling the wiring harness over toward the center of the compartment & that was pushing the battery toward the frunk.
I'm sure if I had left it like this the battery would have worn the harness.
I rerouted the starter cable so it wasn't pulling on the harness & that solved the problem. The harness now sits farther toward the right side as you are looking in the battery compartment. The hold down works as it should now.
