New Gas Cap
why?
can anyone tell me why we needed to change caps in the first place ?can can can anyone tell me why we had to change out the gas caps in the first place ? I never had a problem with mine ?
January 23rd, 2013
[h=2]Can-Am™ Roadster - Fuel Cap Replacement[/h]BRP Spyder
Dear Can-Am Roadster Owner,
Bombardier Recreational Products Inc. ("BRP") is conducting a safety recall on certain vehicles.
Our records show that you own a potentially affected vehicle.
[h=3]What is the potential problem?[/h]
The fuel cap may not seal properly the fuel tank filler neck. Fuel vapors in the presence of an ignition source could result in a fire.
[h=3]What should you do?[/h]
  • Call an authorized BRP Can-Am Roadster dealer to advise them that you need a new and improved fuel cap. This part will be at no charge to you.
  • OR
  • Make an appointment to have your fuel cap replaced. This part replacement should take less than 10 minutes to complete. The dealer will perform this work at no charge to you.
[h=3]What to do if you feel this notice is an error?[/h]
This notice was mailed to you according to the most current information we have available. If you no longer own this vehicle or the owner's information in this notice is incorrect, please contact BRP at your earliest convenience.
[h=3]If you have questions, need assistance, or wish to find the nearest authorized BRP dealer:[/h]
Your continued satisfaction with your BRP Can-Am Roadster is important to us. Please understand that we have taken this action in the interest of your safety and your vehicle proper operation.
Sincerely,
After-Sales Service Department,
http://www.spyder.brp.com/owner-cen...s?PostID=963a0f0b-b4f8-4976-a77c-a14f011bf2ce
I don't know what you mean by "new" gas cap. I have a 2014 and Can Am hasn't sent ME a new gas cap. My old one is stuck. The gas station had vise grips but they didn't help. It ratchets in both directions, so I guess the channel locks come next. Is there a GOOD gas cap in the auto parts stores?
Anyone found out what Stant cap will fit? Too many of these things are failing and I don't want to be stuck somewhere out of gas.
The new Gas Cap was for the 2010 spyder RT S. You will not be getting one as your gas cap is the new version.
The ratchet is broken on your current gas cap . I think the only solution is a pair of channel locks to remove the gas cap.
Good Luck.
I am not sure what gas cap would be suitable for the spyder other than an OEM gas cap because of the thickness of O rings on the OEM gas cap.
I got mine off with great pressure and vice grips. But now it won't go on or come off. Just spins freely.
Just leave the gas cap off as it might not come off when you need gas and don not have channel locks with you. You need to get a new one. Sorry to say your current gas cap is now garbage.
The "New" gas cap was one realised as a recall in 2013 (January 2013 I think) so you will have the "New" one on your Spider already.
Before the recall people used to recommend fitting the Commander ones as they fit but were much tougher than the standard ones.
