RE: Locking pin--the thingy that keeps the seat down until you turn the key to release it for fill up or other under the seat maintainence.
When installing the Corbin seat--some of us removed the shock mechanism as well as the locking pin and just leave the seat unlocked since we don't have to raise the seat to fill the :ani29: with gas.[/QUOT
on our RTL! We opted for the Corbin seat in stead of the Can-Am I wiggle around to much and the Corbin sits just like a good western saddle and I can sit in one of them all day long, Shortly after we had ours installed we went to raise the seat to do something under there. And the seat lock ,post would not let go. so off to the Can -Am dealer. service manager listened to my tale of woo and went xox it, inserted the key, pushed it While turning and lifted the seat right up. several months went by and I tried it with moderate success. THen one day it would not open This time I went to cC robin. Service tech was the seat installer, he tried it and finally got it open . We left and for months it would an would not open. Open for me! It did it again so went back to Corbin same tech but this time he found the problem, I'm sure! If your seat refuses to unlock every time check the two rear mounting bracket bolts and you will probably find one that is slightly loose. They are a pain to tighten so be sure to take a patience pill. Before attempting. He confessed to my spouse that they had just figured out the cause of the problem.
