Tulefog
My original front tires were cupped at 16,000 miles, so I ordered a set of Federal EVOs online, same size as originals. I got the tires mounted at Cycle Gear and they added 2 ounces of EZ Beads to each tire, and after a couple hundred miles at 18 pounds pressure, they are much smoother riding than the old ones. EZ Beads are ceramic beads about half the size of a BB, very light, and when a tire is changed, they can be added carefully just before they seat the bead, or they can be added if the valve core is removed. All the old wheel weights are removed. We will see how they work this season, at this point the tires made an improvement in the handling and ride.
