Need wiring help with NMN signal lights
jetskier
Got the NMN signal LED's and the Kewlmetal bezel lights but because the LED puck wires are too short to go all the way through the light stud I need to know how to wire them in using the stock wiring.
In the first shot you can see the puck wiring is too short for the attaching stud shown below and to the side of the wiring...
So, I have to use the stock wires from the Spyder and pull them through the stud and into the Kewlmetal housing to solder and seal to the above puck wires...
Is the polarity as shown below? - Black to Black and yellow/orange together onto the light grey? As the wires are sealed in to the bulb connector block I'll have to snip them off and discard the stock housings entirely. :(
Thanks in advance.
I have from a really good source, :D that NMN sells that same size LED cluster with 24 inch leads on it.
That would be the easiest way to solve this problem, just using that style cluster. :thumbup:
MM
Cheers MM but I have just received this kit in the UK so changing to the other puck would take a few weeks to sort I reckon. A bit if snipping and extended wiring should be OK shouldn't it?
Yes you can extend the wires if you want no problem. :thumbup:
MM
