Need to replace Glove box cover - any help/advice on removing old lid?
Libamo
I own a 2015 Can-Am Spyder RT SE6 and needing to replace
the glove box lid or cover only. I have the new lid and it’s very
temping to try and pry off the existing cover but not sure where pressure should
be applied without damaging it. Help!!
Don't just pry it off, you won't get the new one back on that way. I am going to go look at mine to see how the hinge is fastened to the lid. You may have to remove the upper panels on both sides to get to the lower part of the hinge.
A few years back I looked into possibly adding a Coil Spring to the Arms on the LID ..... after much research I gave up ..... and I don't do that often .... Good luck .... Mike :thumbup:... I'm curious so I just re-visited that Fiche ..... the door is TWO pieces and both are about $ 350 total ..... AND there are actually TWO springs on the Arms. $21.00 ..... again good luck .... Mike :thumbup:
