Need suggestions for upgrading stock brake lights
gman214
Went for a ride this evening and the guy trailing behind pulls up and says you have no brake lights. It was right before dark. So I checked the brake lights and they're working but for safety I need to upgrade to brighter lamps or LEDs. Need suggestions!
Choices choices..!!
If your brake lights quit working the nanny will put you in limp mode...as to what you can do, there are brighter bulbs, there are leds, and then you can add lights to the front fenders that work with the brakes. I just added them...
attachment.php
brighter bulbs and outriggers...:thumbup:
Tricled & rivco SOMA lightsImageUploadedByTapatalk1432376784.633995.jpg got @ spyderfest. Fyi longer led on top is tricled, short led is the SOMA (stay off my a**) that modulate when i step on break. I like em & do feel safer can see red glow on back of blinkers & edge of saddlebags from my mirrors, so i know I'm lit.
Whelen TIR 3
I just added a Whelen TIR 3 flashing led emergency light to my RS-S. This dude lights up the whole hood when I hit the brakes! GOOGLE it. Sorry have not made the video. I mounted it under the stock light. You will have to fabricate a bracket and mount it on the panel under the stock light.:cheers:
I added the light system from one of the sponsors of this site, they have changed their name, I went with the centre led lamp with the signal lamps and the stock lamp upgrade, very bright and usefull, can switch from steady brake lamp to flashing and then steady brake lamp. Sorry do not remember the name of the company. 2008 sm5
