Need PARK help
0992
SpyderLovers Sponsor
When you put your SE6 in park, does that lock all 3 wheels or just the rear or just the front 2?
If I jack up the rear wheel, will the bike roll away or is park also locking the front wheels?
0992
Only one..!!
wheel the rear. It is cable operated and only applies the rear brake. So chock the fronts if you are raising the rear wheel to be safe...:lecturef_smilie:
WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAT
0992
:hun:...IMHO.....there is no such thing as "PARK " with the SE-6 transmission......Do you mean -when you apply the BRAKE ....If YES , the Brake is for the rear wheel only .....The transmission should go into neutral by itself ....but that may not happen until you re-start the bike ................Mike :thumbup:
:hun:..The transmission should go into neutral by itself ....but that may not happen until you re-start the bike :thumbup:
When the engine is not running, the transmission is disengaged regardless if you put it in neutral or not. That is why we have the beeper to remind us to apply the parking brake.
