NEED O RING HELP
JKMSPYDER
Well-known member
I just received my engine plug for the 1330 engine from Gold Plugs. The plug came with a black O ring already on the plug nearest the hex head. But there was no O ring out toward the end of the plug. I guess I could order the rings from BRP but does anyone have a part # or size from Home Depot or Lowes? I would like to have extras anyway.
That's how they come, I used the washer from my old plug. Here's a tip, put the old plug in very HOT water to remove the washer, and then put the washer in hot water to put it onto the Gold plug. Also, when you order Oil Filters from BAJARON, he sends new washers, which you may not need to use at every oil change. I don't, not unless it breaks. Mike :thumbup:
