rhansen309
I need some help. I had the idea to add my Sirius radio to my 2011 RT. I installed the antenna on top of the trunk and ran the wire up to the right side out the right side speaker grill. I have a ram mount on the right handlebar. That is where the radio will go. First problem - I added two Powerlet outlets to the front. I ordered the first one and installed it in the left front speaker grill. This one is a cigarette outlet. I then ordered a second one; it needed to be custom built. They sent it but it was a Powerlet outlet not a cigarette outlet. I called and to their credit they are sending me what I want with a return envelope. I am ok with that. I connected the red to the positive on the battery and the black to the negative on the battery. Unfortunately there is no power to the outlet. At the same time I added the pig tail for the battery tender. That seems to be working. Second problem is I can plug in the radio to the cigarette outlet in the truck and it works, but when I connect the Scala Team Pro headsets to the radio the volume is so low that when the bike is running I can't hear the radio. Any help would be appreciated. Thanks.
:banghead::banghead:
