Adventurer
There is a small plastic panel that attaches to the OEM seat by way of two plastic posts pressing into rubber grommets on the seat (one on each of the left and right sides). The Ultimate 2up seat does not have the holes/grommets for attaching the plastic panels. Has anyone run across this issue previously and did you find a solution?
I thought about grinding the posts off the panel and just tucking it under the edge of the seat, but wanted to see if there was a known better solution first.
