Need help with power outlet
DrJohn
I just got the BRP Power Outlet for the F3 (219400510). It has two USB sockets. I thought it would be a cigarette lighter socket. Are accessories now equipped with USB plugs? I'm not sure what to do with this thing.
John
If it doesn't suit your requirements, maybe send it back and ask for cigarette socket. I use the USB to charge my phone and Ipod.
I used the plug under the pillion seat. And remember when you do fit it, you need to have the motor running to make it live.
For some strange reason, this is the only one Can-Am specifies for the F3. I'm not sure if it was intentional.
John
I have added the 12V outlet under the seat on our F3. I believe the part number (from the 2015 accessory catalog) you need is 12V · 219400366. The catalog actually shows a USB and 12V version in the F3 section.
Enjoy the ride!
Lee
Lighter plug
attachment.php
John
Dr John, I got mine from eBay, $8.00. I mounted it on the left panel with a quick disconnect so I can still take panel completely off. I also got the USB plug for it, Walmart. works great.:doorag:
Power outlet
Hi DrJohn, can you installed the BRP Power Outlet for the F3 (219400510). I want try figure out how hard is it and if I can install in other place different back seat
thanks
Has anyone installed it on a F3-T? It says it is compatible, but the F3-T has the rear shock air adjuster where the regular F3 has the mount for this. I cannot find any other place to put it.
John
John, my dealer had both....the one with USB posts and the one with a cigarette lighter which I bought as my tire compressor uses the cigarette lighter style power plug. I installed under the passenger seat. Why BRP only shows the USB for the F3....who knows.........I believe the cigarette lighter style was actually listed for the RT.....but fits the rear F3 accessory power outlet perfectly.
