Need Help with locating Fuse please!
latony007
Before anyone says it i tried searching and could not find anything. I need some help. I have tried unsuccessfully for a few days to figure out where to get replacement fuse/relay parts. The big black ones that are in the front fuse box and control the display, headlights etc. I even went to can am and searched through the diagrams. I have an issue where the electronic display is not coming on so i took the fuse out and put it back in and that worked a couple times and finally it stopped working. I then switched it with the headlight one to make sure it was the fuse and it worked. I need to buy another one but i cant seem to locate it anywhere. i tried a local auto parts store but no luck. i tried Amazon which i thought had everything in the world but could not find it, maybe i am calling it the wrong name or something and i even tried the diagrams of parts on the can am site. If anyone can direct me to a link where i could order one i would very much appreciate it!
Thanks
Fuses and relay
The little black relay that are in the fuse panel are at NAPA, Autozone, O'reilly. Take the bad one in the store. They have them.
i tried that, to Oreilly and Pep boys and neither had it and were unable to look it up and i brought it with me. None of the ones they had on the shelves were even close as these have 5 pins and they did not have anything with more than 4. I guess i could try autozone but i would not have high hopes for it. There must be a link to order these, even if its at one of those stores and not carried in stock. Still need help locating as i have tried looking up on line too but just putting in relay leads to a million results and can am relay leads to no results.
That's very odd. A well stocked autoparts store should have them. I bought one from a NAPA store several years ago.
Tony you need to find a Napa Auto Psrts store
Napa was closed, who closes on saturday by 5? lol
Hey this looks like it! im excited now lol. I will call them and see if they have it. I also checked the original thread and looked like Autozone had a duralast one with part # i will try that too. I knew you guys would come through as always!
Thanks!
ok i am back again. First off let me say thanks again. Second i dont know where you guys all are that are paying 8$ for these relays but i wish you would ship me a box full. Mine was over 20 and i got one from autozone and one from Napa. 3rd does anyone know the part # for that large master relay 1 up in the left corner? i am having a gauge/starting issue and have tried swaping all three of the smaller relays with each other and still the same problem. Is there anyway to test if these relays are bad? Other have suggested it may be a battery problem ( i have a new post on the issue) and i am going to follow their advice and try and jump it tonight see if that helps. But i would still like to know what part is for the main relay 1.
Thanks!
