need help with custom dynamics channel lights
They should have come with instructions. Did you look on their web site? If they are like TricLeds, they are easy to install. Main thing is to be sure the channel is clean, clean, clean before installing. You need to pop out the tip light, access the wiring. Using the connector supplied, clip the black lead with the gray line from the strip to the orange tip light wire. Clip the black to black. Hope this helps.
I could never find a video on the installation but it was a pretty straight forward install on my wife's RS. I did find that the LED strip was a tad too long so I cut them down and it still looked great. You can cut it at the third from the end. I hooked hers up to act as signal lights as well. This has to be THE best thing you can put on your Spyder for being seen at night. If someone can't see you then they have to be legally blind. :roflblack:
