need help with BUDS2
Even though I am a pain in the ***, every once in a while i am good for something :roflblack::roflblack::roflblack:
Glad to see that i was helpful.
Cruzr Joe
Success. For the cluster anyway. Reflashed it to 13.20. Thanks to Cruzr Joe. The key here is this paragraph in the instructions. "NOTE: Both diagnostic cable and USB cable are required to do the update." Considering I was working without instructions. That was not obvious. Dropped by KW Surplus and they had the cable. I thought it would be harder to find. The only minor glitch was that Windows Defender stopped things thinking the program was doing something bad. Clicked on the shut up and go away button. Worked just fine.
My number one pet peeve is not fixed but a lot of other stuff looks fixed. So they are moving forward anyway. The following are what 13.20 was to address.
PROBLEM
The following problems were communicated to
BRP regarding the large panoramic 7.8" wide LCD
display.
– Bluetooth pairing
– Fuel average consumption
– Music could not be started in the Music App
– Impossible to launch or exit apps
– Volume adjustments when using the Genius
Map app
– Mute mode (volume OFF) not saved when
power is OFF
– Sound not stable when switching the audio
source during an announcement
– In Bluetooth connection, the music stops after
selecting helmet as the audio output
– Japan certification information.
So to update. I did get a key added. As I suspected. The dealer sold me the wrong key blank. They gave me another key to replace it. The right one this time. I had no trouble adding it to the list.
