daveinva
Good news, bad news.
Regular readers may recall I installed a Yoshi R-77 exhaust a month or so ago. Liked the sound, but the gurgling at low RPM and popping + outright backfiring on decel was too much.
Bought a Juicebox Pro; installed it this weekend. Hated the stock airbox-- what a mess!-- so after I had it out, I replaced it with the KewlMetal air intake.
After all the wiring and installation, I selected the Map #3 setting for the Juicebox Pro (according to Two Bros, setting 1 is for stock, setting 2 is for a single pipe, setting 3 is for a dual-pipe-- but I've also seen folks here with a single pipe and aftermarket air filter/setup use setting 3, so that's what I chose to start).
I only had about 20 minutes to take it out tonight, but I made the most of it, mixing some stop-and-go with 70 mph highway running.
The good news?
REALLY noticeable difference. The low RPM gurgling I got with the Yoshi was immediately gone. Even better, the entire RPM range felt like a continuous band, had no hesitation at any point in the throttle. Found myself INSTANTLY going faster than before-- probably not technically, but seriously, the Spyder just winds out with this set up, it's going to be *very* challenging to dodge those county and state "performance awards" now.
The sound is definitely different. Low RPM sounds a little clackety-- am I actually hearing the butterfly vanes opening and closing?-- but high RPM sounds quieter.
Seriously: this feels like a different bike now. I can't wait to try it out in the twisties, the power just feels like it's instantly "on" now whenever I want it. :thumbup:
The bad news? I still got a *little* popping on decel and downshifts. Not enough to alarm me, but enough to tell me that I need more than 20 minutes to gauge how serious this is.
So, my question for the wisdom of the forum: if after all that I *still* have some popping, what can/should I tweak with my JB settings? Should I try the #2 map? Or will I have to tweak the individual RPM ranges? Any suggestions? I did hook up the JB to my computer, I saw the ability to make custom maps, but I honestly don't have the first clue on where to start, which ones to decrease/increase/etc. And, like I said, the bike feels like it runs great *now*-- it's just the little bit of backfiring that I'd like to eliminate, if that's possible.
Thanks for any suggestions...
The good news?
