need help. headlight issue
cowboys
i searched to see what might be the cause. the lights keep comming on and off. i drive for a little bit and the lights just go out. then they will come back on in a few miniute. any ideas. what should i look for. thanks for any input.
Go right to the Fuse box and reseat all the relays .You may wish to glue some foam to the top inside of the cover to keep them tight in their sockets .
That would be my first step..
Had a similar problem on a Goldwing. If all else fails, it may be corrosive contacts in your dim switch. I don't know how sealed they are.
