NEED ASSISTANCE
den2614
I bought the Spyderpops Bumpskid for my 14 RTL. Has anyone installed this Bumpskid? Any assistance is appreciated.
Many of have installed this product but I am not one of them, lol. However, I recommend that you search for install threads for it and you should find plenty of info. Good luck!
I have one and installed it. Pretty easy install. Just make sure you exactly follow the instructions. Be careful when drilling the additional holes, especially those close to the radiators.
:agree: Those extra mounting holes are pretty important; they help to tie the entire front bodywork together in a much more solid way. :thumbup:
as far as drilling... I might suggest to use a piece of PVC pipe (I used 1/2") cut the PVC pipe just long enough so that the drill goes thru it enough to get the hole drilled .... but will limit the drill bit from getting close to the radiator.. this might save an expensive repair..
osm
Deep breath....
Spyderpops instructions are great. Just relax follow them and take your time. Not a race and you can stop and come back later...:thumbup:
OSM's suggestion is great! the job was very easy, directions very explicit. Was my first farkle and an examination of the underside shows it was very, very wise purchase.
I bought one but had my dealer install it when I brought it in for an oil change. 1/2 hour labor.
The instructions that came with the skid were very clear and easy to follow. A person with average to low mechanical ability should have no problems.
My hang up was drilling two holes in the :spyder2:. For me--:yikes:
